I tried to install this manually.But there was a problem in the last step.
@Thiago_Goes @chris
hi, Thiago & Chris. I have the same problem.
Can you tell me how you solved this problem Thanks
i copy the folder to desktop not solve this problem~ ![]()
Whether I didn’t generate the problem caused by this folder(\run\honeybee_scenario)
I had the same problem, but when I put the file on the desktop, the problem didn’t resolve
There’s a good chance that this issue is the result of the bug here that has been fixed and the patch is available via the LB Versioner component:
@vijesh 's second issue seems a bit different but the message is indicating that the SQL result file is open in another program and has been locked. So I assume that closing that other program should allow the results to be read from the SQL file.
