Hi @chris
I’ve just installed LB 1.2 package with compatible Radiance/E+/UrbanOpt 0.5 and I am having some issues getting urbanopt to work and it is the tool I need to most atm.
Initially I was getting the following error: “1. Solution exception:No URBANopt installation was found in dragonfly_energy.config.folders.”
Then, I have tried running setup-env.bat file from (Dragonfly / UrbanOpt error - #24 by chris) but think it made things worse as the error reported now is as below
Also, not sure if it is needed to run the commands below after installing UrbanOpt? Guess no?
c:\urbanopt-cli-X.X.X\setup-env.bat
%HOMEPATH%.env_uo.bat
Any help would be really appreciated.
