We are Adding 5 New Daylight Compliance Recipes to Ladybug Tools
Hello Ladybug Tools community,
As we announced earlier this year, as part of our goal of further integrating the LBT Grasshopper plugin with the needs of large professional projects, we are starting to expose new recipes for several standard daylight compliance recipes.
This first release adds 5 different compliance recipes to Ladybug Tools:
You can find them under the Honeybee Radiance recipes tab.
Getting Started
To make it easy for you to get started, we have released new sample files for each of these compliance recipes. These sample workflows demonstrate the minimum required setup such as aperture groups and programs.
The sample files can be found here. You can also use the Ladybug Samples component to load them into Grasshopper after installing the latest version.
In addition, here is a video that gives you a high-level understanding of aperture groups and programs.
Input models
There are four basic criteria for the input models, however, the required application varies depending on the recipe.
  • Sensor Grids
    The model must contain Sensor Grids, which are used in all grid-based recipes to calculate the daylight levels.
    • Required in: All recipes
  • Rooms
    The model must contain Honeybee Rooms, which are used in combination with Window Groups or with Honeybee Energy Programs – basically, Rooms are a precondition for Window Groups and Honeybee Energy Programs. See more in the sections below.
    • Required in: LEED I, WELL, BREEAM 4b
  • Window Groups
    The model must contain Window Groups, which are used to calculate sDA according to IES LM-83. You can create the group manually or automatically, using either HB Dynamic Aperture Group or HB Automatic Aperture Group, but you should only use one of the methods. If you have a model with Window Groups, you can still use the model in recipes where grouping is not required.
  • Programs
    The model must contain Honeybee Energy Programs, which are used to categorize the building and space types. Programs are exclusively used in the BREEAM recipe. Please refer to the BREEAM section or the sample file to see how to use the programs.
    • Required in: BREEAM 4b
Post-processing
Unlike running the non-compliance Honeybee recipes like annual daylight, these recipes include post-processing, which means that additional post-processing should not be required, although you can still feed the data into existing Ladybug Tools components for further custom analysis.
Installation
You can access the latest recipes either by using the LB Versioner component, or by using the latest version of the Pollination single-click installer for Grasshopper or Rhino.
Note for Pollination users
If you have been using any of these recipes through the Pollination Grasshopper plugin, you can safely replace your workflow with these new native components since they are the exact same recipes under the hood.
Recipes breakdown
To help everyone get started, here is a quick, simple breakdown of the five newly integrated recipes and the basic criteria they follow to calculate compliance or award points. As a quick rule of thumb, all of these track annual daylight, with the exception of LEED II.
As always, we highly recommend familiarizing yourself with the basics of these codes and simulations before using them.
LEED I (v4.1) - Annual Daylight
  • Compliance Basis: Spatial Daylight Autonomy (sDA) and Annual Sunlight Exposure (ASE).
  • Criteria: To achieve credits, a target percentage of the space must receive at least 300 lux of daylight for at least 50% of the annual occupied hours (sDA 300/50%), while ensuring that excessive, glare-inducing direct sunlight (over 1000 lux for more than 250 hours, or ASE 1000/250) is kept to a minimum.
LEED II (v4.1) - Point-in-Time Daylight
  • Compliance Basis: Point-in-time illuminance levels under specific sky conditions.
  • Criteria: Unlike its annual counterpart, this recipe looks strictly at two precise snapshots: 9:00 AM and 3:00 PM on a clear day near the equinox. Points are awarded if a specified percentage of the space falls securely between 300 lux and 3000 lux during both hours. If glare control is enabled the upper limit of 3000 lux is disregarded.
WELL (v2, Q2 2025) - Annual Daylight
  • Compliance Basis: Spatial Daylight Autonomy (sDA) (through IES LM-83) or target/average illuminance (through EN 17037).
  • Criteria:
    • Feature L01 (Light Exposure - Precondition): Requires baseline daylighting to be met, such as ensuring regularly occupied spaces achieve sDA 150/50% > 30%, or a target illuminance of 200 lux over 30% of the space for 50% of daylight hours.
    • Feature L06 (Daylight Simulation - Optimization): Earns up to 2 points based on performance tiers. Tier 1 requires sDA 300/50% > 55% or a target illuminance of 300 lux over 50% of the space for 50% of daylit hours, while Tier 2 requires sDA 300/50% > 75%, or a target illuminance of 300 lux over 50% of the space AND average illuminance of 100 lux over 95% of the space for 50% of daylight hours.
BREEAM 4b - Annual Daylight
  • Compliance Basis: Evaluates annual daylight by requiring both average daylight illuminance and minimum point illuminance targets to be met. It checks compliance across a specific number of absolute hours per year depending on the space type.
  • Criteria: For example, in Office and Education spaces, at least 80% of the area must achieve an average of 300 lux and a minimum of 90 lux at the worst-lit point for at least 2000 hours per year. Other spaces, like residential units or retail sales areas, track alternative targets such as 100 lux or 200 lux over 2650 to 3450 hours per year.
    • For a breakdown of the criteria please refer to the documentation.
EN 17037 - Annual Daylight
  • Compliance Basis: Evaluates annual daylight by requiring both target illuminance and minimum illuminance targets to be met.
  • Criteria: It tests annual climate data against a dual benchmark evaluated across a percentage of the space for at least 50% of the daylight hours: achieving a target illuminance (300 lux) across 50% of the space, and a minimum illuminance (100 lux) across 95% of the evaluation space. Daylight hours are defined as the 4380 hours with the largest amount of daylight.
Next steps
This is just the starting point. Please try the recipes and let us know if you find that any recipe is missing a specific output you need. Please don’t hesitate to raise an issue. We are looking forward to hearing from you.
This is great @mikkel !!
Thanks for adding these compliance recipes to the ever-growing set of possibilities of LBT.
Admiring your great efforts @mikkel
Thanks alot for everything @mikkel!
Quick question though regarding the EN 17037 standard - specifically what you use as basis for the schedule calculation:
Are you sure about using Global Horizontal Illuminance rather than Diffuse Horizontal Illuminance as basis for the schedule?
I’m an architect/engineer based out of Copenhagen and have been running EN 17037 calcs using ladybug tools for a while now (million thanks for an awesome product btw), and my own previous research led me to use the diffuse ill as schedule basis to calculate the 50% percentile daylight hours.
I did initially use the global (seemed intuitive to do it that way). In a nutshell:
  • Climate Studio/Solemma allegedly use diffuse horizontal to calculate the schedule.
  • Previous notes I wrote based on simple Claude research: “global horizontal illuminance includes the direct beam, which is spiky and orientation-sensitive; direct normal is worse. Diffuse horizontal is a stable proxy for overall sky availability, and it’s consistent with Method 1, which anchors target daylight factors to the median external diffuse illuminance (E_v,d,med) of the local climate. Ranking on diffuse keeps the whole standard internally coherent.”
Am not saying diffuse is the way to go, but rather that I’m interested in finding out what the optimal approach to get the best results is (one issue I’ve been getting is consistently getting slightly poorer results than the simpler Lightstanza models or other radiance-based calcs).
Thanks again for everything your team has been doing.
Greetings from Copenhagen,
Wow! These new components are awesome. @mikkel
@day1savage About whether to use global or diffuse illuminance:
The EN 17037 is pretty clear about this in chapter B.4. It says (translation from my German edition): “Standardized climate files contain an annual time series of 8,760 hourly values for diffuse horizontal illuminance (e.g. EnergyPlus weather file, Meteonorm weather file, Satel-Light). Daylight hours are determined by ranking (i.e. from highest to lowest) the 8,760 values for diffuse horizontal illuminance and then extracting the first (i.e. the highest) 4,380 hourly values.”
Global horizontal doesn’t appear in this definition at all. It only shows up in Note 2 right after, and only for the special case of horizontal daylight openings with diffusing glazing, where E_v,g,med from Table A.4 stands in for E_v,d,med.
Thank you for the feedback, @day1savage and @smooooon. I can quickly change it to diffuse.
You can get the changes by updating via LB Versioner.
Hi @mikkel ,
First of all, thank you very much for these recipes. These streamline our daylight scripts by quite a lot!
You mention that sensor grids are necessary for the scripts to run. I’ve tried the LEED opt 1 recipe and noticed that it runs fine without a sensor grid. If I’m not mistaken it automatically assigns a grid to all rooms with 0.54m grid size.
For visualization after the simulation it’d be good to also output this grid. Or, as you said, make it necessary for the model to have a Sensor Grid to begin with.
Kind regards,
Marc
Secondly, I just found out that since I installed the CUDA toolkit and have CuPy working successfully, the LEED option 1 recipe fails towards the end of the simulation with the following error:
Error message
Runtime error (PythonException):
The recipe failed to run with the following error(s):
2026-08-03 14:51:42 ERROR: "LeedDaylightOptionOne" failed. See below for more information:
    TypeError: type ndarray doesn't define __round__ method
Execution Summary
Scheduled 128 tasks of which:
* 124 ran successfully:
    - 1 AddApertureGroupBlinds(...)
    - 1 CalculateTwoPhaseMatrix(...)
    - 10 CalculateTwoPhaseMatrixLoop(...)
    - 1 CreateDirectSky(...)
    - 1 CreateRadFolder(...)
* 1 failed:
    - 1 LeedDaylightOptionOne(...)
* 3 were left pending, among these:
    * 3 had failed dependencies:
        - 1 CreateVisualization(...)
        - 1 LetLeedDaylightOptionOneFly(...)
        - 1 _Main_e0b315f8Orchestrator(...)
This progress looks :( because there were failed tasks
Traceback:
  line 122, in script
Kind regards,
Marc
It is true that it is technically not a requirement since the grids are created if they don’t exist. We originally allowed the recipes to run without grids to make it easier to not fail on the cloud platform, but in Grasshopper we can stop the recipe from starting by checking for grids, similar to how it will return an error if there are no rooms. I will add this check.
There were bugs of this exact type earlier, but I am not able to recreate the issue. Can you share the model here or in a PM?
I just found out that the issue is actually related to my comment regarding the grids. When supplying a model without a grid AND having CuPy working, the error comes up. When supplying a model with grid, it works as expected.
Attached the Grasshopper definition with the two options. LEED.gh (62.0 KB)
I am still not able to recreate the issue with your file. Can you share the log file of the failed run? You should find it in a path similar to this:
C:\Users\[USERNAME]\simulation\[MODEL_NAME]\leed_daylight_option_one\__logs__\logs.log
I updated the recipe, and you can get the changes by updating your core libraries with the LB Versioner component. It should block the recipe from starting if there are no sensor grids in the model.
Of course, no problem. Attached the log of the failed run: logs.log (721.6 KB)
After running the LB Versioner it is not an issue anymore though, as the grid is now required. But there might be some other underlying bug. Hope the log can help!
Great work @mikkel, looking forward to try them out!
I just updated honeybee to the version 1.10.50 and I don’t see the recipes, is that normal?
I also tried running the scripts from the github folder and i get the following error:
“Solution exception:Recipe “annual-daylight-en17037” is not installed.”
I’m using a computer in which I don’t have fully admin rights, maybe the update didn’t go well?
Hi @mikkel ,
I’ve come across another hiccup, this time in the EN17037 recipe.
When running it, already in the beginning of the run, it errors out. First I suspected that it’s because I was supplying it with a WEA-file instead of EPW, but both fail, though seemingly in slightly different ways. I’ve attached log files for both options.
EPW-version: logs.log (14.7 KB)
WEA-version: logs.log (14.0 KB)
Grasshopper definition: EN17037 error.gh (69.5 KB)
I hope it can help in figuring out what’s wrong.
Kind regards,
Marc
Hi @pmcmm,
I assume so. You get that error message because the recipe is not in the folder where all the lbt-recipes are installed. Did the installation/update not return any message?
Hi @marctavenier,
From the EPW log file I can see that you do not have the latest version of honeybee-radiance. It’s at least ~two months old. In the Wea log it cannot find daylight_hours.json, which is a file that was added to that step of the recipe in honeybee-radiance within the last two months.
Try to update the libraries again.
Hi @mikkel, hi @marctavenier,
I ran into the same failure with the EN 17037 recipe (HB Annual Daylight EN17037, Ladybug Tools 1.10.x) and I’m adding my findings in case they help.
Symptoms
  • Recipe ‘annual-daylight-en17037’ fails at RunTwoPhaseDaylightCoefficient. CreateDaylightHours runs, but daylight_hours.json and wea.wea are not found/copied, so the next step cannot start. This matches Mikkel’s comment about daylight_hours.json.
  • Updating everything with LB Versioner to 1.10.50 did not fix it for me, and the error came back when reopening the file. [Installed versions from `pip list`: honeybee-radiance X.Y.Z, lbt-recipes X.Y.Z, pollination-annual-daylight-en17037-full 0.1.25]
  • Passing a Wea instead of the EPW as input did not help either: in my install the CLI `honeybee-radiance schedule epw-to-daylight-hours` parsed the Wea as an EPW and crashed with an IndexError in ladybug/epw.py.
  • Setting reload_old_ = True did not make Queenbee skip CreateDaylightHours.
Workaround that gave me valid results
  1. Generate the daylight hours schedule myself from the EPW: the 4380 hours with the highest diffuse horizontal illuminance (epw.diffuse_horizontal_illuminance.highest_values(4380)), written as daylight_hours.csv (8760 values of 0/1).
  2. Run the plain ‘HB Annual Daylight’ recipe (enhanced_ = False).
  3. Post-process with the CLI: honeybee-radiance-postprocess post-process annual-daylight-en17037 <daylight_hours.csv> -sf
    (use an absolute path for -sf, a relative one resolves against the current working directory). Note: in this version results are .npy files, so the legacy honeybee_radiance.postprocess.en17037 module, which expects .ill files, does not work.
This produces summary.json with the EN 17037 levels (minimum/medium/high). I validated it on a single room with a sanity check on sensor counts, sun-up hours and DA values.
Question: is there a known fixed version of honeybee-radiance / lbt-recipes for the official recipe? Happy to share logs.py / logs.log if useful.
Alessandro
