I have been using Honeybee by referring to this video (https://www.youtube.com/watch?v=zl-9Eyo7bPo).
However, a problem has occurred as the attached image shows. The orange warning comment has said, “1. Honeybee cannot find a compatible EnergyPlus folder on your system. Make sure you have EnergyPlus installed on your system. You won’t be able to run energy simulations without EnergyPlus. Check Honeybee_Honeybee component for more information.”
I have attempted to do the same thing as the video shows, but I have not been able to. Moreover, some people have found the same problem, looking at the comments on the Youtube page. I was just wondering if I could get a solution to this problem.
Thank you
Kind regards
