Hi Everyone,
I have been trying to perform the simple task of importing an IDF model into Grasshopper. For this, I selected the LoadEModel component from HoneyBee. Instead of loading the model, this produces the following error:
- Solution exception:An OpenStudio installation was found at C:\Users[myusername]\ladybug_tools\openstudio-3.4.0\bin\openstudio.exe
but the OpenStudio executable is not accessible.
After trying different things, I need some help.
I am using:
- Rhino 7
- Ladybug 1.5.0
- OpenStudio 3.4.0
OpenStudio is now installed under
In other locations, it wasn’t even found by Ladybug.
Thanks for your guidance.
Additional note: The HB Check Versions component also produces an error:
- Solution exception:index out of range: 1
All outputs say “No data was collected…”. When OpenStudio wasn’t found by Ladybug, I got versions for lbt_gh and python.
SOLUTION
After doing everything with admin rights (Rhino execution and installations), the described errors vanished. Now I’m struggling with EnergyPlus version incompatibilities… ![]()
