I finally wanted to start emigrating to the new LBT components like PIT_Grid-Based, PIT_Views-Based and Glare Analysis.
I started with the PITView using your ViewBased tutorial as a basis and adding the new PIT “metric”.
The component analyzes, but eventually reports the following error: Invalid Results Folder.
You connected the Model without any Views to the recipe and Views are needed for Point-In-Time-View simulations. You’ll see that, in the latest development version of the plugin, we now give an explicit error about this:
Maybe you should just be using the latest stable release (Run the versioner, restart Rhino, then run “LB Sync Grasshopper File”). You should also make sure that you’re using a compatible version of Radiance:
