Rhino 7 and LBT Versioner
I get the following error on the Versioner while trying to update in Rhino 7. On Rhino 6 it works fine:
Runtime error (TypeLoadException): Could not load type ‘ComponentAce.Compression.Libs.ZLib.ZStream’ from assembly ‘Microsoft.Dynamic, Version=1.1.2.22, Culture=neutral, PublicKeyToken=7f709c5b713576e1’.
Traceback:
line 526, in init, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\zipfile.py”
line 1009, in open, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\zipfile.py”
line 1082, in _extract_member, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\zipfile.py”
line 1028, in extract, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\zipfile.py”
line 316, in unzip_file, “C:\Users\ayezi\ladybug_tools\python\Lib\site-packages\ladybug\futil.py”
line 154, in download_repo_github, “”
line 241, in script
Thanks for reporting, @AbrahamYezioro . It looks like this issue happens because McNeel is using a newer IronPython in Rhino 7 and it seems that the native IronPython zipfile module is not working correctly in this new version.
Perhaps @wim could verify whether this is an issue that McNeel could address on their end by fixing the zipfile module in their IronPython plugin. If not, I assume that we’ll have to develop a workaround for the lack of a functioning zipfile module on the Ladybug Tools end.
In the meantime, you can rest assured, @AbrahamYezioro, that running the Versioner in Rhino 6 updates the Ladybug Tools plugin for BOTH Rhino 6 and Rhino 7. So, just running the versioner in Rhino 6 will allow you to keep everything updated for now.
This is what i did … :slight_smile:
Hi -
We assigned one of our developers to take a closer look at this. Thanks for flagging the issue, @chris!
-wim
@AbrahamYezioro
Would you mind checking the file info on the C:\Program Files\Rhino 7\Plug-ins\IronPython\Microsoft.Dynamic.dll on your machine? Does it match this?
Also would you mind running a search for Microsoft.Dynamic under C:\Windows\assembly as see if any other version of this dll is installed globally?
Hi @eirannejad,
Yes. It is a match.
No. There is not another one like this.
Thanks for your help, @wim and @eirannejad .
I just wanted to note that I downloaded and installed the most recent Rhino 7 but I was unable to recreate @AbrahamYezioro 's issue. So it might be worth confirming whether you are using the most recent version, Abraham.
My R7 version is the very last one, SRC 7.1.20322.15001, 11/17/2020, from today.
This is the screen i get:
Hi @chris @AbrahamYezioro. Today I installed Rhino 7 latest version (as mentioned above by Abraham). I have Rhino 6 installed too. To test the working of both Legacy and Lbt plugin, i dragged them to Rhino 7 canvas. Except for Ladybug legacy and honeybee legacy, all other plugins from legacy and LBt throws an error with Rhino 7 but works fine with Rhino 6. Can you suggest how can I solve this? Two things come to my mind
  1. Completly uninstall Rhino 6 and reinstall all plugins with Rhino 7 or,
  2. Reinstall all plugins using Rhino 7 keeping Rhino 6 too on the same disk location.
lastly even i get the same error as Abraham when updating butterfly and LBT
@Asisnath,
I believe you need to run the .bat file according to these instructions, stage 4. Remember to close Rhino before.
Hope it helps.
Hi @AbrahamYezioro. You were correct. After installing Rhino 7, again I have to run the batch file. Now it’s working. But the update components for both LBT and legacy throws the same error as yours.
So now we are two with the same problem. Even though @chris is not having it probably there are/will be more users having it. Let’s hope @eirannejad will catch the error.
Ok. I’ll do a reinstall of all the apps on my machine and will try to replicate this error. So far I’m not seeing any which is very weird.
Hi @eirannejad. Any update on this?
@Asisnath @AbrahamYezioro I reinstalled Rhino and the apps and can not replicate this issue. Let’s figure out where is the conflicting “Microsoft.Dynamic” coming from. Would you please run a system-wide search for “Microsoft.Dynamic” and see how many versions are available on your machine? For some reason the runtime is trying to load an incorrect version
Hi @eirannejad,
This is what i’ve found in my machine Indeed i have many versions.
Okay great. Seems like there are at least 5 different versions. Are you testing this LBT component of Revit? (Rhino.Inside.Revit). If not let’s focus on the one inside C:\Ironbug and get the dll info so we can see what version it is
So far i’m not testing the RHino.Inside.Revit, but maybe at some point i will.
The ironbug version is different than the one you posted above. it is 1.1.2.22.
Can be that? Not sure since i’m assuming @chris is also having it and he is not having this issue.
In any case i also checked the other version files.
The one in C:\Program Files\Autodesk\Revit 2021\SDA\AddIns\BackendBindings\PythonBinding is 1.1.0.20.
Also same version for the one at C:\Program Files\Autodesk\Revit 2021\SDA\AddIns\BackendBindings\RubyBinding
All the others are 1.1.0.1000
Thanks @eirannejad,
Great! The ironbug version seems to exactly match the dll version from error above
I think this is the culprit. This seems to be related to LadyBug Tools. If this is not what you are using I suggest removing it (make backups) and testing LBT in Grasshopper again
I did a fresh LBT install on my machine and I don’t have the ironbug directory
This is it!!
I neutralized the Ironbug folder and the versioner is running now fine in RHino 7.
@chris and @MingboPeng FYI. Any ideas how to solve this at your end?
Thanks @eirannejad!
