Hello all!
I am working on sDA and ASE calculations with LB 1.3.0, I followed the script provided by @AbrahamYezioro here https://discourse.ladybug.tools/t/sda-ase-with-lb-1-2-0/14435
I changed the components from LB 1.2.0 to LB 1.3.0
I got results for my model, but they are not normal, it looks like there is no window (just a void in the wall) and no shadings, for example, I got 3000% for ASE which is very weird!
I don’t know if the problem is in my model, though it is a simple room with one window and a balcony as a shading device.
I will attach my script, hope someone can help me.
When I changed the parameters of the model (Aperture ratio, balcony depth, and type) the results of sDA still the same for all options.
You can see the sDA results in this pic and the previous one are same.
