Hi all, I am working on a project requires batch running thousands of energy simulation. I combine Colibri and honeybee to make the whole process.
I witness that, when I first run the simulation, the set zone threshold component only take seconds, like below:
But the running time will greatly increase after running several times:
I try to close the gh file and reopen it, the same high computation time. Only if I fully close rhino and reopen the gh file and do the same process, the time will recover to 1.6 second.
I think @EmmanuelR had run into the same trouble 2 years before:
https://discourse.ladybug.tools/t/high-duration-of-computation-for-set-energyplus-zones-thresholds-component/3319/5
There seems a bug somewhere I suppose, which can not be easily caught in single-run workflow. @mostapha @chris
