There’s a good chance that this issue is the result of the bug here that has been fixed and the patch is available via the LB Versioner component:
@vijesh 's second issue seems a bit different but the message is indicating that the SQL result file is open in another program and has been locked. So I assume that closing that other program should allow the results to be read from the SQL file.
