Error: Runtime error (TypeErrorException): iteration over non-sequence of type NoneType
Traceback:
line 35, in <genexpr>, "C:\Users\user\ladybug_tools\python\Lib\site-packages\lbt_recipes\version.py"
line 33, in check_openstudio_version, "C:\Users\user\ladybug_tools\python\Lib\site-packages\lbt_recipes\version.py"
line 255, in run, "C:\Users\user\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py"
line 148, in script
How to fix this and how to use this new component ? , if there is an example available this better
Hi @chris
In Ruby folder installation i fix the error with encoding but it look that openstudio use another ruby folder where the problem still exist, i search and read the topic you share but no solution yet
Thank you for posting the solution to this, @seghier . I am sure that you have helped a lot of people who might experience this issue and may find this post. Iāll see if I can add a better error message to the plugin when this encoding error arises.
Thank you , this will of course help people.
Another thing after some tests i found that ruby 32bits and ruby 3.0 64bits donāt work with Openstudio.
The version 2.7.4.1 64bits work better, but maybe other people donāt have a problem with this.
I try to update lbt-recipes, i set python from ladybug folder as interpreter but i got this error
pip install -U lbt-recipes
Fatal error in launcher: Unable to create process using '"c:\users\mingo\appdata\local\programs\python\python37\python.exe"
"C:\Users\user\ladybug_tools\python\Scripts\pip.exe" install -U lbt-recipes': The system cannot find the file specified.
Hi @seghier ,
I donāt know how exactly you were able to get that error but you should just be able to use the LB Versioner to update your installation to the latest development version. That component will automatically call pip under the hood to update all of your core libraries (including lbt-recipes).
Hi @chris Iāve been receiving this same error message with a bunch of my ladybug tools components. Iāve tried the solution above, updated my Rhino version and used the LB versioner but it still has not been resolved. Did you have any other solutions?
@chris & @mostapha, just a cheeky request to bump up the priority on @amynuccio 's question above we need her to do some urgent work and are experiencing delays because of this issue.
Pablo had the same problem a while back but it went away by itself magically (it came up at the end of the screen recording I sent you that one time) - Iām unable to solve it, but if you could at least give me some pointers/ideas maybe I can dig a little deeper.
Iām sorry but, if this is the same issue that seghier encountered, then it is on the side of the operating system and its compatibility with the simulation engines so it is outside of the realm of what we can fix within the ladybug_tools software. You should find the same issue on that machine with any other software that uses Radiance or EnergyPlus/OpenStudio.
Can @amynuccio work with an IT department to make sure that the operating system can support UTF-8 unicode characters?
Actually, I just noticed that the OpenStudio team changed the way the encodings work in the last few months:
⦠and these changes have made it into the OpenStudio 3.3 release that happened a little over a week ago. Iāll start working towards updating the development version of the LBT plugin to OpenStudio 3.3 and maybe we can see if this will address this issue.
